Bug? - Event Structure Data Node Change on Edit Event Structure Case
[LabVIEW 2010]
This is an issue I am seeing with the Event Structure whereby the Event Data nodes are changing when I edit the Event Structure case.
I expect the Event Data Nodes not to change when I do this.
Cheers
-JG
Unable to display content. Adobe Flash is required.
Certified LabVIEW Architect * LabVIEW Champion
(3,137 Views)
I was unable to replicate this using LabVIEW 2010f2.
(3,128 Views)
This code was bought up from LV 7.0. I wonder if an artefact could be causing this issue with all the Event Structures?
(3,095 Views)
Can you upload the code, or is it too large? Can you create a smaller test case in 7.0 which displays the problem when loaded in 10? Does the same thing happen if you do it with a brand new VI?
(3,086 Views)
