Bug? - Copying Controls in Group Removes Binding
[LabVIEW 2010]
When I copy a control binding remains intact however when I copy the controls in a Group binding is removed.
Cheers
-JG
Unable to display content. Adobe Flash is required.
Certified LabVIEW Architect * LabVIEW Champion
Message 1 of 10
(4,522 Views)
Works just fine for me LV2010SP1. Copied a grouped controls to a new VI and the Group persist.
Message 2 of 10
(4,506 Views)
That is not what the thread is about.
Binding is not persistant (as oppossed to Group as you mentioned).
Message 3 of 10
(4,493 Views)
Oh you mean Binding, capital B Binding, as in Data Binding a property of the control/indicator. Not ungrouping (unbinding) like I mentioned. Maybe others were also confused, thus overlooking the discussion.
Hmmm, who can answer if this is intentional???
Message 4 of 10
(4,482 Views)
Sorry for the confusion but I have never heard the term binding using with grouping front panel objects in LabVIEW.
Anyways, yes, I am referring to PSP/DataSocket Binding of the object - which I was hoping the video clearly shows?
Unfortunately I cannot edit the thread title or the original post. 😞
Message 5 of 10
(4,471 Views)
Hello jgcode,
I really like the video, it's quite helpful! How does it work for you if the two grouped objects both individually had Data Binding prior to being grouped? The behavior is most likely due to the created control without Binding imparting it's status to the group when copied. It'll be interesting to see if this only happens with PSP or with DataSocket as well.
Thank you,
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Message 6 of 10
(4,459 Views)
Hi Deborah
I noticed this as I was copying groups of controls (with binding and without and decorations in the same group).
I was only using PSP and not DS.
But I think there is a bug here.
Cheers
-JG
Message 7 of 10
(4,454 Views)
Hi Deborah
Were you able to raise a #CAR from further testing?
Cheers
-JG
Message 8 of 10
(4,420 Views)
Hello jgcode,
The CAR number filed is #298993. We really appreciate you reporting this, customer feedback helps make future versions of LabVIEW the best yet! I will try to keep this forum thread updated on the status.
Thank you,
Deborah Y.
Deborah Burke
Message 9 of 10
(4,410 Views)
@Deborah Y wrote:
Hello jgcode,
Thank you,
Deborah Y.
Hi Deborah
Yes! My intention of these posts is to make LabVIEW better.
Thanks for the #CAR.
-JG
Message 10 of 10
(4,400 Views)
