Bug? Build Status Explore button does nothing
LabView 2011 Service Pack 1 Version 11.0.0f1 (32-bit)
After building an application the "Explore" button in the build status window no longer works.
This button should open the directory that is shown in the build status window.
=== Engineer Ambiguously ===
(3,547 Views)
what happens when you right click the exe and select explore. I am just trying to understand the problem
(3,537 Views)
When you say "no longer works", does it mean it worked for you before?
When did ot stop working? (After ugrading to SP1, or after patching to F1, or some other random time?).
Could it be that the folder is already open?
(3,534 Views)
Seems to have stopped working after the F1 patch.
Also checked, does not matter if the folder is already open or not.
It used to bring the folder to the front if it was already open before.
(3,525 Views)
I don't understand? You mean right click in the dialog box?
(3,517 Views)
You can right-click the build entry in the project and select "explore" to get similar results.
(3,511 Views)
Yes I guess this option should be working fine
(3,505 Views)
