Buffer with multiple data plots solutions
my channels sampling rate I want to be 1000Hz but with the dt of 1/100 and new data to be displayed every second on the graph
Message 21 of 29
(1,855 Views)
So you want to take your 1kHz sample, average it down to 100Hz (dt=1/100) and then update the graph every 1 second with the 100Hz data? The buffer should be fine with that for 5 minutes of data since that's 20x smaller and therefore about 1MB of data.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 22 of 29
(1,843 Views)
Yea but with your modification of the dt when I change my loop timing to 1000, it doesnt work.
Should I go back to how mine was or is there something else to do with yours since I didnt quite get what you did
Message 23 of 29
(1,826 Views)
What do you mean by "doesn't work"? I changed it to 1000 samples, 1000 ms timer, and 1000 decimation input and it seems to be working fine to me.
Cheers
Message 24 of 29
(1,811 Views)
when you look at the timestamp on your graph is there a difference of 5 min from your t0 to tf. What Im saying now I get alot of data but on the timestamp on the graph is wrong. To get a 5 min buffer, it increases very slow and to would start 2-3 min less than the actual time clock
Message 25 of 29
(1,801 Views)
Message 26 of 29
(1,799 Views)
Accepted by topic author ritch_by_nature
It looks like it's a problem with your consumer loop, doing something funky with the data before graphing. I assume it has something to do with you chopping down the sample rate, but writing the dt through as the same value. This would result in the same t0, but a different length of data (in the time domain).
Here's a screenshot of what I'm seeing. The graph I put in there on the left is correct, but your graph has the weird timestamp issue.
Cheers
Message 27 of 29
(1,796 Views)
I was looking at it wrong. I was hoping the whole time to get 5 min buffer display with the decimated data plot in the consumer loop. To get that Id have to aim for a higher buffer size I see. thanks alot
Message 28 of 29
(1,788 Views)
Let me know if you need any further help. In the mean time, please mark one or a few of the posts here as the solution, so that people in the future can find a solution if they have a similar application. Most likely the solution is from 3 weeks ago as a solution to your original question.
Cheers
Message 29 of 29
(1,773 Views)
