Buffer problem
I have to aquire my data (multiple channels) in data records of 1000
samples (EDF format 1000Hz sample-rate), therefore i must set the
"number of scans to read" in the "AI read.vi" at 1000. This causes my
while-loop to slowdown at a rate of 1 second per loop, then when a want
to display the achieved data the refresh rate is also 1 frame/s. Is
there any possibillity to achieve data in bloks of 1000 samples(: ch1
1000 samples....ch2 1000 samples.... etc.). But that I can see my
achieved data with a frame rate of 50 frames/s, working with multiple
while loops doesn't work the acquisition loop slow it down?!
Anybody?
Best Regards,
Thijs Boeree
Message 1 of 9
(6,038 Views)
Absolutely. I have done this many, many times.
Let's understand what is happening first. If you are just using a loop
that sets up a continuous acquisition, and reads 1000 points every
iteration, when the AI Read is called, you stop the data acquisition
"thread". If any other data acquisition VI is called, it won't execute
until this AI read is finished, or 1 second has elapsed (because of your
1000 Hz sampling rate), even if it is in another loop.
Therefore, to eliminate this problem, take a look at the Labview example
under examples\daq\anlogin\anlogin.llb\Cont Acq&Chart (Async
Occurrence). This vi uses the DAQ Occurrence VI which allows Labview to
generate an occurrence (like an interrupt) when the buffer contains a
certain amount of data (say, 1000 scans!), and you can hold off doing
your AI Read of 1000 scans until the buffer contains that much data.
What does this do for you? It doesn't tie up the data acquisition
thread anymore. In a separate loop, now you can perform another AI
read, but this time you're going to read 1 scan, and you're going to
read it referenced to the END of the buffer. This will get the last
scan that went into the buffer (the most recent data), and that is what
you can display on your graph. This will NOT interfere with your
buffered acquisition.
The only trick is that when you make the call to read the 1000 scans in
your other AI Read, you must make that referenced to the "beginning of
buffer", because your other AI read will move the buffer marker, which
is the default read location of the AI Read.
Give that a try. I know it works. Let me know if you have any trouble.
Mark
In article <39F9481D.E19030B0@amc.uva.nl>,
want
> Anybody?
> Best Regards,
> Thijs Boeree
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 2 of 9
(6,042 Views)
First of thank you for the fast response!!
I opened the example "Cont Acq&Chart (Async Occurence)" and already made
another while loop, putted the AI read in it, but now I don't know what you
mean by "you're going to read it referenced to the END of the buffer." How
do I wire this? I not that familier with LabView yet, can you send me a
simple VI where the seperate loop is displayed, i don't need the Cont
Acq&Chart because i already have 'm.
What do you do with LabView?
Best regards, Thijs Boeree
> Mark
Message 3 of 9
(6,038 Views)
On the AI Read VI, there is an input which is a cluster that contains
the position and read offset where the read from buffer should occur.
You can set the position to the "End of the buffer", and the read offset
to zero. This would retrieve the most current piece of data entered
into the buffer.
If the position were "relative to the beginning of the buffer" and then
the read offset was the iteration of your loop times the number of scans
to be read per loop, this would read x scans in the correct position of
the buffer for your DAQ occurrence loop.
Mark
In article <39FD396D.CDE41D66@amc.uva.nl>,
made
what you
How
a
loop
execute
your
example
Labview to
a
doing
what
in
of
which
trouble.
> > Mark
Before you buy.
Message 4 of 9
(6,038 Views)
Mark,
I'm trying to do the same with DAQmx on an RT PXI system.
I have a timed loop with 500ms loop time for 1000Hz Counters and Analog Buffered reads. The control loop has a 20ms loop time. Is it possible to read from the buffer, using DAQmx Read in these two loops, without altering the current read position?
Is there a way to configure the DAQmx task(s) simiar to the example with the"DAQ Occurrence VI"?
Regards
Roger Isaksson, Damill AB
Message 5 of 9
(5,952 Views)
If I am correct, the code in the threads below should achieve this?
DAQmx: http://forums.ni.com/ni/board/message?board.id=280&message.id=1272
Traditional DAQ: http://forums.ni.com/ni/board/message?board.id=170&message.id=139740
Regards
Message Edited by Roger Isaksson on 09-07-2005 04:25 AM
Message 6 of 9
(5,907 Views)
How do I get an example like the one your talking about if I hav daqmx? I have been trying to do just this but cant find an example.
Thank you,
Justin
Message 7 of 9
(5,462 Views)
Justin,
From the previous post, there is a piece of code at this forum which should do the job.
Message 8 of 9
(5,425 Views)
I have a similar problem. I've inherited some labview 7.0 software for a data acquisition system. The system uses two pxi 6052e daq cards and currently uses 3 channels on each card and the software works great; however, when I converted it to use 4 channels per card, there is an error code -10846 regarding buffer offerflow, size, timing, etc. I've tried everything imaginable to get this fixed and it's not working. There is an RTI capture vi which sets the buffer size for each card and it is set at 10000 (I've changed it to lower and higher values and with larger values the problem occurs less frequently). I've also changed the wait time divide by number in the case seen in the attached photo (I am still unsure of the purpose of dividing here so if someone could explain that would be awesome). I've also changed the number 1920 to higher and lower values (Again, I'm not sure of the purpose of this value, but I do know that it controls the size of the output matrix from this sequence). The error only occurs on the top buffer read sequence. Any and all help is greatly appreciated. Thank you very much.
Message 9 of 9
(5,209 Views)
