Brushing up on text base reading somebody elses formula node
I need to brush up on my text base skills.  I am reading somebody elses code and it contains this formula node.  Any help understanding the logic inside or seeing a LabVIEW equivelent would be much appreciated.
formula node
Message 1 of 10
(3,580 Views)
Can you attach the actual formula node in a new VI. I doubt that we currently see the full code.
Message 2 of 10
(3,548 Views)
Very odd snippet of code.
All but the first line should be self explanitory.  Everything on the first line though are bitwise operators.
Basically it is stating that if the Nth bit of variable A is a 1 (N being j-i) then set X=2
For example: A = 11, j=6, i=3, f=8
A (in binary) is 1011.  So A right shifted 3 places (6-3) = 1 so 1 & 0x01 = 1 -- so set X = 2
Edit: fixed a typo
Message 3 of 10
(3,547 Views)
Here is the whole node.  Thanks
Message 4 of 10
(3,533 Views)
Hey Don, can you explain the &0x01 portion?
Message 5 of 10
(3,530 Views)
That is masking out all the other bits and only looking at the 0th (1's) bit so you can get a simple 0 or 1, rather than other numbers in the event other bits are set within the number that you don't care about.
Message 6 of 10
(3,526 Views)
Ah, thanks. Now we see the curly brace at the end. 😄
Message 7 of 10
(3,518 Views)
Pat_H wrote:
formula node
What is up with the 'f' outside the box?
Message 8 of 10
(3,510 Views)
Accepted by topic author Pat_H
How about some nice G code to look at.
Message 9 of 10
(3,507 Views)
Thank you all!
Message 10 of 10
(3,482 Views)
