Browser VI
I know that there is a VI used to start up your web browser and load a specified page, but I'll be damned if I can find it in the many supplied LLBs.
Can anyone point me in the right direction?
Chris McCrory
Project Engineer
_______________________________________________
E-mail: c.mccrory@sp-tech.com
Website: www.sp-tech.com
Tel: 01382-622226
Fax: 01382-622565
(5,530 Views)
> supplied LLBs.
In the help directory there is a folder called intlinks. Inside of
there are two LLBs that LV uses to connect a person to various NI web
sites that are deemed useful. If you use that you will have a platform
independent way of firing up a web browser to a particular URL. Note
that some of the VIs in intlinks.llb will run when opened; so you should
drop them as subVIs using VI... then open them up and figure out how
they work.
Greg McKaskle
(5,530 Views)
