BridgeVIEW Networking stops after a certain time
We have a BridgeVIEW v2.1.1 system with several server PC's which are
connected over the network with one client PC.
The server PC's are responsable for the I/O's and the client PC is used for
monitoring the measurements and to control the settings for the process. In
total we have over 4000 tags in the system. A lot of them are network tags.
If we startup the BridgeVIEW engines it all runs fine but after a while the
network communication stops. We had this problem already in the v2.1 of
bridgeVIEW after we installed some bug fixes which we got from NI. After
reinstalling the v2.1 without the bug fixes the network communication was
running OK.
We hoped that the latest version 2.1.1 solved all our probl
ems we have with
it since a long time.
Does any other user of BridgeVIEW have the same experience and is there a
solution?
regards, Dennis Motshagen
INCAA Computers BV
www.incaacomputers.com
tel. +31-55-5425001
fax. +31-55-5429000
(2,917 Views)
Please apply the following patch to your BV 2.1.1.
ftp://ftp.ni.com/support/bridgeview/BV21%20fixes/BV%20Networking%20Patch/
If the problem persists after applying the patch, please get in touch with
our Support team at: support@ni.com.
Khalid
"Dennis Motshagen" wrote:
>Hi,>>We have a BridgeVIEW v2.1.1 system with several server PC's which are>connected
over the network with one client PC.>The server PC's are responsable for
the I/O's and the client PC is used for>monitoring the measurements and to
control the settings for the process. In>total we have over 4000 tags in
the system. A lot of them are network tags.>If we startup the BridgeVIEW
engines it all runs fine but after a while the>network communica
tion stops.
We had this problem already in the v2.1 of>bridgeVIEW after we installed
some bug fixes which we got from NI. After>reinstalling the v2.1 without
the bug fixes the network communication was>running OK.>>We hoped that the
latest version 2.1.1 solved all our problems we have with>it since a long
time.>>Does any other user of BridgeVIEW have the same experience and is
there a>solution?>>regards, Dennis Motshagen>INCAA Computers BV>www.incaacomputers.com>tel.
+31-55-5425001>fax. +31-55-5429000>>>
(2,917 Views)
