BridgeVIEW Client/Server Application
We have recently been developing and Industrial Monitoring and Control Application
using BridgeVIEW. The software application consists of a SERVER application
that is controlling and monitoring the industrial application, and a CLIENT
software application (in BridgeVIEW) that has a subset of the functionality
to control and monitor the HOST software application from remote terminals.
This means we are using the network tags to synchronize the applications.
I learned of several VIs that are going to be neede to make this application
fully functinal. They are: rgstr RVBVC, rgstr RVBVS, bvtcp client, & bvtcp
server.
Does anyone have any experience using these VIs in a real-world application,
as well as with a BridgeVIEW
Client/Server application.
Thanks.
(3,033 Views)
Hello Wayne,
You do not have to really know about these VIs. All you have to do is to
run these "register VIs" once on your systems to register the Remote Server
and Client. You'll then use the Network Tags to impelement the Server/Client
network. Also, you will not be using the TCP/IP VIs yourself. All this
will be transparent to you.
Khalid
_________________________
Application>using BridgeVIEW. The software application consists of a SERVER
application>that is controlling and monitoring the industrial application,
and a CLIENT>software application (in BridgeVIEW) that has a subset of the
functionality>to control and monitor
terminals.>This means we are using the network tags to synchronize the applications.>>I
learned of several VIs that are going to be neede to make this application>fully
functinal. They are: rgstr RVBVC, rgstr RVBVS, bvtcp client, & bvtcp>server.>>Does
anyone have any experience using these VIs in a real-world application,>as
well as with a BridgeVIEW Client/Server application.>>Thanks.
(3,033 Views)
I would agree with Khalid's post. I have been doing this with Bridgview quite
easily.
However, if you need to port this data to machines that are not running Bridgview
software somne of the VIs that come with the Internet toolkit can come in
handy. Although I have found that at most times third party tools to port
data has been easier for me - perhaps because of familiarity or sometimes
"access to familiarity". If you need any help, please feel free to e-mail
me.
Sudhi
"Khalid Ansari" wrote:
>>Hello Wayne,>>You do not have to really know about these VIs. All you
have to do is to>run these "register VIs" once on your systems to register
the Remote Server>and Client. You'll then use the Network Tags to impelement
the Server/Clien
t>network. Also, you will not be using the TCP/IP VIs yourself.
All this>will be transparent to you.>>Regards,>>Khalid>>_________________________>"Wayne
Garret" wrote:>>>We have recently been developing
and Industrial Monitoring and Control>Application>using BridgeVIEW. The software
application consists of a SERVER>application>that is controlling and monitoring
the industrial application,>and a CLIENT>software application (in BridgeVIEW)
that has a subset of the>functionality>to control and monitor the HOST software
application from remote>terminals.>This means we are using the network tags
to synchronize the applications.>>I>learned of several VIs that are going
to be neede to make this application>fully>functinal. They are: rgstr RVBVC,
rgstr RVBVS, bvtcp client, & bvtcp>server.>>Does>anyone have any experience
using these VIs in a real-world application,>as>well as with a BridgeVIEW
(3,033 Views)
