Boolean selection and conversion to numeric
I currently have 3 different boolean values being produced by my program. At any 1 time, only 1 of them is equal to 1 and the others are equal to 0. I want to have a case statement which I can use to create a different numeric value based on which boolean value is equal to 1. How can I differentiate between the boolean values in order to use them in my case structure?
Note: Once i have the right case selected the number will be sent to RobotStudio.
(1,491 Views)
Try this snippet:
or this one if you're feeling mathy:
Here's a simple implementation, but it doesn't catch the error condition where more than one Boolean is True:
There's lot's of ways your code can find which Boolean is True. Which way makes the most sense to you?
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(1,483 Views)
How about something like this?
  1. When only Boolean 1 is True send 100
  2. When only Boolean 2 is True send 200
  3. When only Boolean 3 is True send 300
  4. All other Boolean combinations send nothing
=== Engineer Ambiguously ===
(1,425 Views)
If only exactly one boolean must be true, I recommend to use a radio button instead.
(1,406 Views)
