Boolean of dynaimc data
Using LV7.1:
I am trying to have a boolean response to 2 "Greater?" blocks. In other words I need to know if  "A is greater than B AND C is greater than D". However A, B, C, and D are the output from 4 formula blocks. The problem is that the output is "Dynamic Data" and not numeric. This is crewing up the final "And" block. How can I fix this?
I've attached a sample of the problem.
thanks,
jason
(2,424 Views)
I've opened up your attached vi.  The output of the two Pass Value Through functions is not dynamic data.  It is a numeric.  The output of the greater thans is boolean.  I don't know why you would see it differently.
18411iA68A730A47C0AE6F
- tbob
Inventor of the WORM Global
(2,414 Views)
