Boolean input & output from formula node?
Hi All,
How do you declare input and output variables to be boolean in the formula node.  See attached example, I want leak and prev to be of type boolean.
Sean
(17,969 Views)
The formula node does not support boolean at the input/output.
Here is what Greg had to say about the topic: http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=17317
(17,962 Views)
Here's an example of how you could simplify the boolean portion of the code:
oh yeah...  pretend the boolean constant and indicator are Shared Variables
Message Edited by Ray.R on 10-13-2009 01:06 PM
(17,958 Views)
