Boolean control with mechanical action configured in Latch mode behaves as if its in Switch mode
I'm currently using LabVIEW 7.1 to develop my application. I have used an event based architecture in my program.
The Boolean controls are placed on a tab structure and based on which is clicked, the appropriate page would be shown. The Boolean controls are configures in a Latch mechanical action.
During runtime, I press a button "A" and the event takes me to the new page. When I click the "Back" Boolean button on that page I'm taken back to the previous page. However the button "A" still remains in "ON" rather than latching back to "OFF".
Am I doing something wrong here? I'm guessing its something simple that I've missed out.
Many thanks for your help.
Cheers!
Sanka Smiley Happy
(3,480 Views)
Hi Sanka,
are your booleans inside the loop? I think the best place is inside the belonging event case. To switch back to the other state, your control has to be read.
Mike
(3,476 Views)
And in LV8 the terminal only has to be placed in the event case, not really connected, to switch back automatically. I thing in LV 7 additionally it had to be wired to switch back (am I right?).
greets, Dave
Greets, Dave
(3,454 Views)
No, I don't think it's ever been a requirement for a control to be wired to anything.
(3,441 Views)
Hey Sanka,
How ru doing?
Hope you're doing fine na.
For your problem, I tried the thing you try to achive with the following techniques:
1. boolean inside event structure: buttons switch back.
2. boolean outside event structure, but inside while loop: buttons switch back.
3. boolean outside while loop: buttons don't switch back.
4. boolean in another while loop: button switch back once another loop update.
In conclusion, I think the best practice is to put a latch button inside its case to make sure it has an appropriate behavior.
Regards, Kate
(3,423 Views)
I just had the same problem, so i searched and found this thread.
My program is a event-driven program, and thus a while-loop outside all cases. By placing the latching button in the loop, but outside the cases it worked for me.
I tried it in the case first, and tried to force reads on the button but it didn't work, same with having it outside as a "global" button.
It's behaviour is abit tricky.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,346 Views)
Your description is incomplete, so we cannot really see what's going on. Can you attach a simplified example that shows the described behavior. SOmething does not sound right.
  • How do you "force reads"?
  • What is a "global" button?
  • Describe "while loop outside all cases". Do you mean "while loop outside a single event structure containing multiple cases"?
  • What kind of events are you using for the booleans (mouse down? value changed? etc.)
(3,340 Views)
