Boolean Shared Variable with Scan Interface
I am trying to pass values from my host vi to the rt vi (vi running on cRIO chassis) for my current project. I ma using the cRIO 9073 with NI 9213 and NI9401 modules.
When I create a shared variable on the cRIO I can successfully read the temperature values on my host PC. However, I have a boolean switch connected to a boolean shared variable on the Host PC but it does not update the DIO port on the chassis connected to the same shared variable. i.e. I have one way communication.
I am using labview 8.6.1
regards
Harshil.
(2,827 Views)
How have you configured the entire thing? It would be useful to post some screenshots of your code.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,812 Views)
