Bluetooth Low Energy receiver sensitivity test
Im using NI PXIe-5644R for testing Bluetooth Low Energy device based on Texas Instruments CC2640R2F microcontroller. I'm trying to perform device receiver sensitivity test described on page 77 of this document: http://download.ni.com/evaluation/rf/intro_to_bluetooth_test.pdf
In general, the test procedure described in document is as follows:
1. Send "dirty" packets from NI PXIe-5644R with proper power.
2. Receive packets in DUT and resend it.
3. Receive pockets in NI PXIe-5644R and compare received packets with packets that was sent at the begining.
How can I implement this procedure using the Bluetooth Test Toolkit in LabVIEW? Is there an example VI available? As result of test I would like to obtain transmission Bit Error Rate.
Thank You
Message 1 of 1
(3,114 Views)
