Bluetooth Connection with Passkey Protected
Hi all,
i'm using LabVIEW 7.1 running on Windows XP SP2. I would like LabVIEW to make a connection to a Bluetooth device with passkey protected.
I use the built-in Bluetooth functions to develop the application (eg Bluetooth Open Connection.vi). So far I can only connect to Bluetooth device without passkey protected.
When the passkey is turned on, I don't see a way to key in the passkey (eg Prompt Window).
Anyone can advise on this issue ?
Thanks !
(3,399 Views)
Bluetooth pairing occurs at the OS/driver level and there are no plans to get this deep into the driver from LabVIEW. I would highly recommend that you submit a product suggestion (explain and identify the needs of your application) at the Product Suggestion Center.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,385 Views)
Hi Adnan Z.
Thanks for the reply.
Actually there was a balloon raised up at the right bottom corner of Windows, where I did not notice earlier.
By clicking the balloon I was able to key in the passkey manually.
This should solve my problem at the moment. Of course I hope LabVIEW can create an input parameter for passkey so the program will run fully automatically.
Thanks again !
kianleong
(3,378 Views)
This will allow you to programmatically pair with a bluetooth device.
You will also have to download the dotnet files from 32feet
http://32feet.net/files/
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
(3,011 Views)
