Bluetooth Communication Between Labview and Rn42
Hello seanpps2,
Can you make your computer talk to the hardware using any other software program, like HyperTerminal? If not, then I'd recommend you to talk to the OEM, since they are more knowledgeable on how to make your hardware work with the computer better than we are. If you are able to communicate with it and the problem is VISA, we would have a great starting point and we will be able to provide better assistance.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 11 of 18
(2,003 Views)
Hi Reds,
I managed to get the communication up . However i encounter another problem . Upon disconnection (via a button to close bluetooth), i cant reconnect one the immediate next try . The subsequent tries will allow connection to be established again . Could it be a that some data are saved ?
Message 12 of 18
(1,995 Views)
Hi seanpps2,
I would imagine that when you push the button from the Bluetooth device to disconnect it, the VISA session is not terminated properly, and it needs yet another try to initiate a valid session. Do you get the same behavior if you terminate the session via LabVIEW?
Daniel REDS
RF Systems Engineer
Help us grow.
Message 13 of 18
(1,988 Views)
Hi REDS,
It works perfectly fine once i disconnect from labview . The problem only occurs when i disconnect through the use of a button. Thanks
Message 14 of 18
(1,982 Views)
Accepted by topic author seanpps2
Hi seanpps2,
In that case I would suggest you first stop the VI so that you don't experience this problem. This way, LabVIEW can manage to end its session appropriately.
Daniel REDS
RF Systems Engineer
Help us grow.
Message 15 of 18
(1,979 Views)
Hi..
Could you maybe upload your code. I am sitting with I think is the same problem. Just can't get i work. It would be really helpfull, I have been working with this issue in several days know.
Thanks.
Message 16 of 18
(1,946 Views)
I saw that you were having a problem with our bluetooth on a forum. Were you able to figure it out?
Thanks in advance,
Aziz
Message 17 of 18
(1,767 Views)
Hi Azizelle,
Since this thread is more than 2 years old, it would be best to create a new thread for your issue. Then we can all help you troubleshoot from there. Thanks!
Message 18 of 18
(1,743 Views)
