Blocking user interface buttons
How I can block buttons in user interface. I have to make an application that prevent all functions from other buttons when one button is turned on. So I have four buttons and only one can be active at a time. If any other button is pressed there should occur an error message. Is there any easy way to do this?
(4,111 Views)
Easiest way to do this is to use radio buttons.
Alternatively, you can use the 'disabled' property of a button by using a property node.
(4,104 Views)
Could you make a little example code for me?
(4,094 Views)
Hi
You can use the property "Disabled" to enable/disable the buttons.
Wire one of the following values to the property to perform the following operations:
0 - enable the button, so that it can be pushed
1 - disable the button, so that it can not be pushed
2 - disable the button, so that it can not be pushed, additionally it is greyed out so that it's state is visible
DavidT: Usually radio buttons are used to select one of several options. I would not use them to active one process and deactivate the other buttons.
Hope this helps.
Thomas
Edit: Example added
Message Edited by becktho on 05-20-2005 09:09 AM
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,093 Views)
Thank you very much. Now I get it.
(4,084 Views)
if you want to use the radio buttons - have look at the example "radio buttons control" shipped with LabVIEW
regards timo
(4,080 Views)
