Block diagram text editor
Just upgraded from 8.0 to 8.2;  It used to be that when I double clicked anywhere on the block diagram I got the text editor so that I could add quick notes.  now in 8.2 I have to manually open the tool box(view- tool pallet)  and select 'text editor', type the text, then reselect the standard selector mouse... wtf???  I can't find any settings that fix this.
  Someone please explain.
Kevin
(3,350 Views)
Is the auto wiring enabled ?
  • LV Menu >> Tools >> Options... >> Block Diagram >> Enable auto wiring
  • or LED on the top of the Tools Palette
(3,347 Views)
What you're looking for is the Lock automatic tool selection option to be enabled. You can set this from the LabVIEW options (Tools->Options->Environment), or as JB mentioned you can just turn on the green LED when you have the palette visible.
(3,340 Views)
Yes you're right ! I must have been very tired to confuse both options ! 5 stars for you and a cup of coffee for me !
(3,307 Views)
