Block application until a task has completed
Hi 🙂
I have something in mind. I am currently working on a lot of data, of course this takes some time and the whole thing runs in a sequence.
Now I'd like the following:
* I'd like a window popping up at the beginning, telling the user to be so kind and wait until the task has finished.
* In the background, the task should be running, but the window should still be displayed
* During this time, no elements of my main front panel should be operateable
* When the task is done, it should close the window
Is this possible ?
(2,663 Views)
Hi
a simple solution is just to use a text message ;where you can change message as
main application progresses. The window is still displayed!!
with regard to point 3
see following thread
Point 4 adjust VI's window properties  so VI closes after use.
chow
xseadog
(2,653 Views)
thank you . .exactely what I've been looking for 🙂
(2,650 Views)
