Bit-String to Hex
Hello
I've got following question: I have a STRING of bits e.g. "01001010". Is there any function to convert it to Hex - code?
(3,594 Views)
See the attached code. I wasn't sure by what you meant by a "STRING of bits" so it shows two different things.
Remember also that the distinctions between binary, decimal and hex are only significant to human beings reading the numbers--computers don't really care. An unsigned 8-bit value is an unsigned 8-bit value, regardless of how it's represented for human consumption.
Note that in a array the LSB is the first element. In a string, the LSB is the far right-hand digit.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,594 Views)
Thanks Mike
That was it really what I need. I know that a computer doesn't care about the values. But I need that to create my PDU --> HEX Code. Its a little bit trick and I hope it will work!
(3,594 Views)
The only other thing you will need to be careful about is the bit order. Does the PDU protocol want to the the LSB or the MSB of each word first?
Mike...
LabVIEW Champion
(3,594 Views)
