Bit Operations
I'm attempting to do some bit operations on a decimal value that I need to output as binary to my instrument. Using universal libraries Digital out vi, I can send an integer value out as a binary number. Is it possible to perform bit operations on a decimal value using the formula node and logical operators? I need to make the LSB, the MSB. For example, a decimal value of 128 in binary is 10000000. I would need to output this as 00000001. I was trying to use a formula node like this: y = (x && 1) ? 128:0 ..... y = (x && 128) ? 1:0 for all the eight bit values. Then I would add all the values up and send that to DOUT. So in my example beginning with a decimal value of 128 and sending it to eight formula nodes I would like to get false values unti
l y = (x && 128) ? 1:0. Then the compound addition would yield one and this value would be sent out to my instrument as binary 00000001. Unfortunately, I get true values out of all my formula nodes. How can I accomplish the bit operations I need to perform on a decimal value and then send it as an integer value to DOUT? The example is simplified, the actual decimal values are large. Any help would be greatly appreciated.
(3,505 Views)
To get 128 in binary (10000000) to 00000001 you can use the rotate function located in function palette under advanced->data manipulation.
(3,505 Views)
If you want to use a formula node, review the C syntax for && (logical AND) and & (bit-wise AND);
For example,
int x,y,z;
x=2;
y=x&&1; // logical AND: y=1
z=x&1; // bit-wise AND: z=0
The LabView AND function (from the Boolean palette, not in a formula node) works like the bit-wise AND.
(3,505 Views)
I don't know about the formula node but you could just use a few labview functions. Change it into an array of bits using number to boolean array and boolean to (0,1). Use reverse array and then change it back to a number using 'not equal to zero?' and boolean array to number. Not sure if that is better or simpler than using a formula node but it is another option.
(3,505 Views)
