Binary string monitoring
Hi All!
I have a tricky task to do 🙂
I get binary string from serial port – 00000000
Then I increase voltage and see if any bit changed its state.
So if I see something like 10000100 I can write:
Bit3 and Bit7 become 1 at 2.5 volt.
How can I do it?
Thank you.
(2,933 Views)
Hi John,
At what stage of the task are you in?
Do you get the reading from the serial port? If not, what did you try?
Once you have the string it's a simple task, you can manipulate strings using Functions->Programming-> Strings....
I'll try to help more once you have a more specific question.
(2,930 Views)
Hi John,
just use sam simple comparison functions:
(2,919 Views)
simply_me  - I have nice clean string from serial port.
GerdW - Look nice but how can i track index of a bit that was set?
(2,900 Views)
Accepted by topic author john7
Hi John,
use Search1DArray repeatedly to get indices of TRUE bits...
Or use a FOR loop to index through the resulting boolean array!
(2,894 Views)
