Binary search 1D array example code bug
Tried to add this as a comment to the Binary Search 1D Array example code in the NI Developer Zone, but I thought I'd add it here as well. The code example is found at:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E46E56A4E034080020E74861
(At the time of this writing) Using the code there to perform a numeric binary search for the value of zero causes a return value of 2147483647 when zero is not in the input array and every value of the input array is greater than zero. The return value should be -1.
This is caused by a bit shift of an I32 value of zero, creating a search index of 2147483647. When the input array is indexed there, it returns (unless you have a VERY large array) a default value of zero. This matches the search value of zero, and the algorithm returns 2147483647, believing it has found a match.
I fixed my version of this code by simply returning a -1 if the found index was greater than the size of the input array.
Hope this shows up for those using that code!
Joe Z.
(4,105 Views)
Hi Joe Z,
The example certainly does not behave as expected when searching for a '0' in an array which contains all positive numbers, and no element with a value of '0'. As you say, the source of the behavior is the shift function which is used to divide by two.
Attached to this post is a screen shot of an alternative fix. I will be taking the example off line shortly to correct this error.
Scott Y
NI
(4,074 Views)
