Big buffer size
Hi there,
I wonder if it's possible, with labview to manage a big buffer
(several Giga) of cluster as a FIFO (The computer will have enought
RAM or swap)? Or do I need to simply manage an big array of clusters ?
Does it exist in Labview an additional module for this kind of stuff ?
Actually I will get on my serial port a stream of data that I wanna
put in a quite big buffer before writing it on my hard drive.
thanks for all.
Ebe
(2,854 Views)
Cyril wrote:
> Hi there,
Well LabVIEW is 32bit and that limits most things to 4GB. But the
limiting factor will be probably your OS instead. Windows and also Linux
do only allow for 2 or 3GB per process to be addressed even if you
manage to cram 100GB into your computer.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,854 Views)
