Big Integer operations or library
Hi All,
 I am trying to find a library that handles operations on large integers(> 64 bit). Does Labview have a native library? If not, can anyone recommend one that they have used successfully in Labview?
(4,110 Views)
What kind of "operations"?
(4,105 Views)
Basically I am looking for a LabView library that can match the operations achieved by a package like BigInt in PERL. http://perldoc.perl.org/Math/BigInt.html
If not all, at least the most used like Add, Subtract, Multiply, Divide, Modulus and Power.
(4,095 Views)
There is no native support in LabView for integers greater than 64-bits. You could represent these integers as string, then create functions that convert segments of the string into numbers in 64-bit sizes and operate on them, but this type of workaround would not be handy for operations like Power and Divide. I did find this link about how a user generated their own library to operate on large integers in LabView, which you may find helpful: http://www.imeko2009.it.pt/Papers/FP_206.pdf
Best,
Dan Nelson
(4,076 Views)
