Modular Data Acquisition
High-Performance Test
06-29-2016 01:03 PM
One way I've worked around this in the past is to separate the booleans and doubles into separate clusters. Then this whole exercise becomes a lot simpler, because you can convert each cluster to an array and use Array to Spreadsheet String.
