Best way to enable/disable multiple front panel controls
I'm a new user of labVIEW. can you please tell me how to enable or disable a cluster programatically at runtime. what i'm trying to do is i've created a radio button which has options as : a)X b)Y c)X & Y. so when i select X the cluster X should be enabled and Y disabled, when i select Y cluster Y should be enabled and X disabled and when i select the third option both clusters should be enabled while the program is executing. I have used case structure and functionally this happens. i only want that it should appear also that this is happening. If possible please help.
Message 11 of 18
(4,264 Views)
Hi shalini,
                Can you upload your VI?
Thanks as kudos only:)
Message 12 of 18
(4,263 Views)
Message 13 of 18
(4,259 Views)
i uploaded the wrong file... kindly go to the properties of tab control n enable it.
Message 14 of 18
(4,253 Views)
What you really mean?For me it seems to be working.What all things you are trying to achieve?Your Tab control seems to be in a disabled state.See the VI that I have attached and explain your problem more clearly.
Message 15 of 18
(4,244 Views)
The tab control was disabled by mistake. As i had written earlier, it is functionally correct, what i want is when i select X, i want the cluster Y in the free running tab to appear as it does when "disable n grayed". Is it possible to do so??
Message 16 of 18
(4,240 Views)
Found the solution. Thank u anyways.Smiley Happy
Message 17 of 18
(4,227 Views)
Hi shalini,
                Good! Please post the VI.Let I have a look at it.Iam not getting exactly what you are trying to achieve.
Message 18 of 18
(4,225 Views)
