Best way to collect 1 encoder sample for every n analog samples
Hello folks,
EQUIPMENT:
LabVIEW 7.1
PXI-6602 - collect quadrature encoder data
PXI-6052E - collect several analog input channels
The 6052E will use its onboard clock (i.e. ai sample clock) to capture analog input data at 50kS/s.  I would like to also use the 6052E ai sample clock to capture the encoder data (for synchronized ai and encoder data), however I want to sample the encoder at 1kS/s.
Is there a "built-in" way to do this, or do I have to create something in my read loop to handle it?
Best Regards,
Chris
(2,698 Views)
Chris,
If you want to synchronize the two cards, you need to share the timebase and a start trigger.  There are several examples that show how to synchronize devices, which you can open by going to Help>>Find Examples.  Then browse to Hardware Input and Output>>DAQmx>>Synchronization>>Multi-Device.  You can input a different Sampling Rate for each device (even though currently they are set up to go at the same rate).
Cheers,
-Christina
(2,665 Views)
