Best way to capture data every 5 ms (milli-seconds) in the .vi diagram when using "Time between Points, and Small Loop Delay tools" ?
- Using LabView version 6.1, is there anyway to change the "Time Between Points" indicator of (HH.MM.SS) to only (mm.ss), or to perhaps only (.ss) ?
- Need to set the data sampling rate to capture every 5 milliseconds, but the defaults is always to 20 or greater; even when the "Small Loop Delay" variable is adjusted down.
Thank you in advance.
Message 1 of 1
(2,393 Views)
