Best way of handling strings
Hi
I am have trouble handling strings.
I would like to know the best way of transposing strings for uploading to spreadsheet file
for example I have a series of comma seperated strings:
string a, 1,2,3,4,5,6,7,8,9,10
string b, 2,4,6,8,10,12,14,16,18,20
string c, 3,6,9,12,15,18,21,24,27,30
string d, 4,8,12,16,20,24,28,32,36,40
etc.
I would like to transpose these strings to a column format:
string a, string b, string c, string d
1,2,3,4
2,4,6,8
3,6,9,12
4,8,12,16
5,10,15,20
6,12,18,24
7,14,21,28
8,16,24,32
9,18,27,36
10,20,30,40
Is there an easy way of doing this so I can manage data better?
Many thanks
Ash
(2,603 Views)
I believe if you were to build your strings into an array, and then set the "Write to Spreadsheet File"'s 'Transpose' input to true, you should get what you're looking for.
(2,595 Views)
Excellent!
I knew there was an easy way.
Ash
(2,589 Views)
