Best practice for encoding and decoding DUT/UUT registers? Class? Cluster? Strings? Bitbanging?
I am architectecting a LabVIEW system to charactarize silicon devices.  I am trying to decide the best way to enqueue, encode, and decode device commands executed by my test system.
For example, a ADC or DAC device might come in both I2C and SPI flavors (same part, different interface) and have a large register map which can be represented as register names or the actual binrary value of it's address.
I would like my data structure to
*) be protocol agnostic
*) have the flexibility to program using either the memonics or hard coded addresses
*) be agnostic to the hardware which executes the command. (
*) I would like to enqueue mulitple commands in a row.
I am thinking a detailed class is my best bet, but are there are examples or best practices already established?
(2,768 Views)
I agree on the detailed class inherited from a general DUT-class. Especially if you want to mix interfaces you need to keep those as far away from your top vi as possible. 🙂
As to the 4th point i'd implement command-vi's as enque and have a in-class command-queue (or possibly just an array of commands).
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,746 Views)
