Beginner question: how do I get while loop to stop when time changes?
Im using a 'Format Date/Time String vi' with a time format string of %H:%M, I want the while to stop looping, when the minute changes. How do I do tjis?
Cheers,
Sam
(3,293 Views)
Hi Sam,
I hope the following ex help you.
If this is not you want kindly explain it further so that we can help you.
Shrek
(3,281 Views)
Accepted by topic author ssteel
Hi Sam,
instead of shrek's fiddling with strings and locals (property node.value is kind of local!) you should use a shift register and integer numbers...
(3,266 Views)
Hi GerdW,
Hey you got it better.
I appriciate it.
Shrek
(3,231 Views)
