Beep
can anyone tell me how I can generate a simple 'beep' from the system
loudspeeker. The sound.vi seems to need a soundcard (which I don't have in
that computer).
Thank for any help
Stefan Schirmer
Institut für Solartechnik SPF
HSR Hochschule Rapperswil,
Oberseestrasse 10, CH-8640 Rapperswil
E-Mail: stefan.schirmer@solarenergy.ch
Tel. +41 55 222 48 26
Fax +41 55 210 61 31
Internet http://www.solarenergy.ch
(4,563 Views)
There is the beep.vi in the Sound palette. (See pic.)
Torsten
> that computer).
> Thank for any help
> Stefan Schirmer
Torsten Levin Tel.: ++49-(0)89-72495-451
Kayser-Threde GmbH Fax: ++49-(0)89-72495-291
Perchtinger Str. 3 mailto:TL@kayser-thre
de.de
D-81379 München http://www.kayser-threde.de
(4,563 Views)
I tried this VI but it only beeps on my computer with soundcard, but not on
the computer with only a system loudspeeker.
Any ideas?
Stefan
Torsten Levin schrieb in im Newsbeitrag:
3A5DB532.CE4D21A8@kayser-threde.de...
> Torsten
in
> > that computer).
> > Thank for any help
> > Stefan Schirmer
> Perchtinger Str. 3 mailto:TL@kayser-threde.de
(4,563 Views)
It should use the internal loudspeaker if no soundcard is present- I've used
it that way so it does work on at least one machine.
I assume you're sure the loudspeaker works? You get the bleeps on powerup?
You're sure there's no soundcard? Some motherboards have the sound hardware
built into the motherboard and you'd have to disable this in the bios. You
may have such a machine even if you didn't specify you wanted audio.
Stefan Schirmer wrote in message
news:3a5ed92c@newsgroups.ni.com...
on
> Any ideas?
(4,563 Views)
Here is a solution to create a beep directly on the PC speaker. Actually it works verry well under Win98, but I think it works on all IBM-PCs without any problem.
(4,563 Views)
