Baudrate?
    Does anybody knows how to know the baud rate in a tcp connection... i mean... if there is a way to know the bandwith for that tcp connection?-.... thanks
(5,335 Views)
There is no such thing as a baud rate for a  TCP/IP connection.  That term only applies to serial connections.  For TCP/IP connections, you are using your ethernet port, so that could theoretically be 10 megabit/second, 100 Mb/sec, 1 Gb/sec.  But of course you are sharing that with all other network activity your computer is doing, and also any other network activity between other computers on your network segment.
(5,318 Views)
   Thanks for the instruction Ravens Fan... actually i was wondering abuout that, the bandwith (BW)... i would like to know the BW of my connection to adjust my rate to send data on it..... so with this i think the network would be less bussy and the data could be sent fluently... is it posible?
(5,293 Views)
