Batch File run via LabVIEW
Hi
I have a .bat file. When I run the file in windows, it shows what operation is happening in the CMD prompt window. If I run the same .bat file via LabVIEW using System Exec, it performs the operation but not showing the operations happening in CMD window. Only Blank CMD window is showing. How to fix it?
(1,215 Views)
Type "LabVIEW System Exec" into Google and look at the first few entries.  The one with the 2022 date and described as a "Tutorial" will probably answer your question.
(1,155 Views)
