I have noticed that when you setup a channel (either in MAX or DAQ Assist) to either aqcuire or generate analog voltages, you cannot select anything larger than 10 Volts in the "Signal Output Range" boxes.
If in theory I can select from -10 to +10, which in reality is an overall range of 20 volts, why then can't I define a range of say 0 to 15 volts? or 0 to 20V?
Is that a limitation of my hardware (PXI-6031E) or a limitation of LV?
If I have a device that works with 0 to 15v signals, I know I could make circuits to either drop the voltage or increase it (wheter I'm doing input or output).
Is there any other way around the limitation?
Thanks!
