Basic TCP/IP and problems
I have been trying to communicate between two VIs using UDP and then TCP/IP.
- For the TCP I have used the example VIs 'Multiple Connections - Server/Client'
- When the VIs are running on the same machine it works fine.
- When using TCP/IP I have replaced 'localhost' with the ip address of machine found using the 'ip to string' VIs and it still works fine.
-When I run the VIs on two different machines that are both connected to the same network it does not work.  The UDP client of course shows no error and the TCP/IP client vi shows Error 63 - The network connection was refused by the server.  The TCP/IP server vi runs okay.
-I know the ports are correct from my tests on the same machine.
-I believe it must be a firewall problem on the PC.  I believe it is not a network issue as I've taken both laptops home and tried to do the above with my home network but it still didn't work.
-Our work PCs run Symantec Endpoint Protection and I believe I must need to add some exceptions to this program.  I would need to get our IT department to do this as it is locked-down.
-The problem is that I don't fully understand what I need to ask IT to do.  They won't be keen to do it anyway but I certainly need to approach them with clear information on what I need if I am to stand any chance.  Can anybody please advise?
Thank you for any help you can offer,
Martin
(2,940 Views)
You're dead on. You will have to ask them to open up the ports you want to use for your application.
André (CLA, CLED)
(2,923 Views)
