Basic Ring control question
This is humbling, but I just discovered something which I find un-intuitive: if I initialize the Strings[] property of a Text Ring control using an empty String array, the ring control resulting from this operation has a Strings[] array size of 1 and its unique element is a string of length 0...
See attached snippet:
(interestingly BTW, my diagram does not use a Ring Refnum and a generic Property Node, but instead directly the Ring's Property Node, but that has been changed upon generating the snippet)
I see that when opening the property dialog for the Text Ring, I cannot remove the last item, whose name is empty, so that's consistent with the above behavior, but I would expect that an empty String array remains an empty string array.
Comments most welcome.
(5,612 Views)
Use the Code Capture Tool.  It is much better than the built in LabVIEW snippet maker.
The element in the array makes sense.  When you drop a new ring onto the front panel, you notice it always starts with at least one item that is empty.  You can't have a zero item ring.  So if you try to feed it an empty array, LabVIEW takes over and turns it into a single element array of an empty string.  If you go into a new string control and try to edit the items, notice you start with an element 0 and you can't delete it.
(5,605 Views)
I don't have a problem with an empty string. I have a "problem" with a Text Ring having one element which is empty. I just don't see the logic compared to an empty Text Ring (i.e. a String Array). But that's just me, I suppose.
(5,595 Views)
Accepted by topic author X.
Maybe it's just semantics.  You can have a text ring with a single element that is an empty string.  You cannot have an empty text ring.  There always has to be at least one element.
A text ring is a numeric datatype.  Actually an integer datatype.  There is no such thing as an empty integer.  It always as to have a value.  The default is zero.  In a text ring you always have to have at least one element you can select.  Which means it has to have at one element of a string array associated with it.
Though you could have a ring control that is a floating point data type such as a double.  And you could have a data value of NaN you could call a sort of null numeric, though I don't think it is really the same principle.
(5,590 Views)
Now HERE is something VERY interesting.
As I mentioned above, I was a bit surprised that the snippet generated from my VI used a generic Property Node rather than the Text Ring Property Node that I originally used.
I just tried the snippet, and contrary to what I was rumbling about before, the size of the Strings[] array resulting from the diagram is 0 (ZERO) not 1!!! (that's BTW what I was expecting to be the "correct" behavior)
What is going on?
If I replace the two generic property nodes back with the Text Ring Property nodes, I get back to the size = 1 I was puzzled with.
What can of worm did I just fall into?
(5,587 Views)
Never mind, the snippet was bogus and created a reference to a non existing text ring, hence the empty String[] array...
Replacing the reference control by a reference to the Text Ring on the FP brings back the "bizarre but expected" (or is it "fine but unexpected"?) behavior.
@Ravens Fan, I think we will blame it on semantics then...
A Text Ring is a numeric, it is not a an array of strings and thus does not behave like one, although, of course, that's pretty much the only way that I can think of using it...
(5,575 Views)
