Ballbar Communication (SAGA) - Progressing :)
Thanks again for severals answers to my previous question. My problem was that, when I was using the "Basic_Serial_Write_and_Read" VI to communicate with the ballbar (serial port), I was getting an error about accessing the port. Then, with the answers I got, I ensured that MAX and Hyperterminal were closed and tried again. And I'm back to my first error about timeout. In MAX, I'm able to read data from the ballbar. When I send *IDN?\n I receive A12345 (its name), when I send *S?\n I get the anticipated data from the ballbar. But, when I try to do exactly the same in Labview, I get timeout error (or access error if MAX isn't closed). So I'm still trying to figure out why I get this time error. I've checked all the properties
(baud rate, bytes to read, ...) and even if I make the same procedure as in MAX, I get this error. I'm a bit confused about why there's a difference between MAX procedure and Labview, so if someone has an idea, I'd appreciate it a lot. Thanks again for helping me solving my problem.
(2,589 Views)
In your string control where you enter the command, do you have "\" Codes Display turned on? This is set by right clicking on the control. If you don't, you are not sending the control character but the strings \ and n. You could also set the VISA serial port properties to automatically send a termination character with each write or do a append string with your command and use the line feed constant on the string palette.
(2,589 Views)
