Roy,
Well, please don't change this behavior, or make it optional! It is very
convenient to be able to select a large number of tree items at once (just
by dragging+ctrl). I have a tree with a large number of categorized input
names, and by selecting/deselecting them, the user can show them in a chart.
The number of clicks is very low as it is now.
I wasn't convinced about the selecting behavior, I tried to check, but could
indeed not find any tree where items can be selected by dragging+ctrl.
Still, it is very convenient.
Wiebe.
"Roy F" wrote in message
news:506500000005000000B9D40100-1079395200000@exchange.ni.com...
> There's a bug here, but not in the way you might think. The behavior
> you are seeing is obviously wrong,
but the real bug is that you should
> not be able to ctrl-click/drag or shift-click/drag in a tree control.
> The tree control in your VI does not have dragging enabled, so drag
> operations should be ignored. When dragging is enabled, it is a move
> operation, not a select/deselect operation (at least not intended -
> sorry).
> I filed a problem report to have this fixed. In the meantime, I
> believe the workaround you mentioned (using a shift-register) is your
> best bet. You might want to use a feedback node around the event
> structure, instead of a shift register, to reduce the wiring (no
> functional difference, just a bit less obtrusive).
> While investigating this I also discovered that shift-click can fire a
> value changed event without a value change (i.e. shift-click to select
> a range, then chift-click the same item again). This is also not
> correct and has been filed.
> Roy
> LabVIEW R&D
