BUG: Not showing Version of .NET assembly
the tooltip does not show version of .NET Assembly:
Although the Assembly has a version:
It is a bug.
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
(3,658 Views)
Sorry, forgot to say:
LV2011 SP1
Eugen Wiebe
Bernstein AG
(3,657 Views)
Are you sure this is a bug with LabVIEW?  What is this ASI_Communication assembly?
Perhaps the issue is with the assembly not reporting itself properly.
How does this look in other versions of LabVIEW?  How do other .NET components appear in this version of LabVIEW?
(3,648 Views)
Yes, Im sure, it is. Windows Explorer shows me the right Version number in the tooltip, even the LabView Selection Dialog shows the right version (BTW: It's an assembly written by me).
The assembly itself reports its version correctly, its only LabView not showing the version correctly in the tooltip.
(Further suggestion: Also the Context help should show the version number of the assembly if you point on the constructor, a method, a property or even the connection line)
In other (older) LABVIEW versions it also occured
BR
EW
Eugen Wiebe
Bernstein AG
(3,645 Views)
Hello Ewiebe,
I tried it with several assemblies ( mscorlib, NIDAQmx ) and I observed the same behavior from the tooltip, all the info about the assembly is displayed except the version. It looks to me that it is a cosmetic bug, and is not related only to your assembly. I will check if a corrective action request is already created, if not I will be creating one.
Regards
Mart G
AE NIC
(3,617 Views)
Hello Ewiebe,
A Corrective Action Request was already created for this bug, the CAR# is 164483. You can check the release notes of the futures versions of LV to check if the bug has been fixed, Thank you very much for bringing this to our attention, we really appreciate your time.
Regards
Mart G
AE NIC
(3,611 Views)
