BUG: Core function using deprecated code
The "Three button dialog core.vi" uses FP.open properties instead of invoke node Front panel:Open/Close (LV2018). That's been deprecated for quite a while by now.
Qestit Systems
Certified-LabVIEW-Developer
Message 1 of 8
(3,590 Views)
But it works, right?
(Who uses that dialog anyway 😉)
Certified LabVIEW Architect
Message 2 of 8
(3,566 Views)
Sometimes you write code when you are first learning LabVIEW and even though it works well, you are perpetually embarrassed whenever other developers look at the BD.
AQ once told me that he would go back and clean up his mess.  I assume nobody wants to develop a full set of regression tests.
Of course,  I don't use any built in dialogs.
  • They poll rather than use Events
  • They are saved with "Dialog" vi properties rather than setting those only at runtime ( Silly way to ask for a three-finger salute in development) set fp.behavior and fp.closable in your dialogs
  • The buttons are too big unless you absolutely must waste space in case of localization.
  • The BD would be improved with CTRL+U
  • No error handling on the property nodes but, nice sequence structures instead
  • VI documentation does not meet my standards
In my opinion,  TBD Core.vi has been obsolete since version 6.
"Should be" isn't "Is" -Jay
Message 3 of 8
(3,522 Views)
Accepted by topic author Yamaeda
In LV2021 it looks like this in the last frame:
So just upgrade LabVIEW 🙂
Message 4 of 8
(3,474 Views)
That method is exactly what the complaint was.
Essentially,  TBD Core, fills in the button text before showing the FP.  Really,  that isn't a bug.  In fact, it's desired since all the p node writes have to happen in the UI Thread and having the text change while the FP is visible and then moving the FP to center it would be a rather poor UX.  This actually is a proper use of the FP.Open method.
Not a bug but, yeah, the code could look nicer.
Message 5 of 8
(3,448 Views)
If I understood the OP correctly, his complaint was about the node being deprecated but in use in LV2018. In Later LV-versions, that is corrected, which I showed. I did not mean anything about it being incorrect. I don't know how the code looks like in 2018 but I assume the behavior is maintained although the deprecated node is used.
I especially like this part of the code:
If anything, Three Button Dialog should be deprecated 😀
Message 6 of 8
(3,443 Views)
Exactly, that's how it should be. When they deprecate code and suggest we use something else i don't expect to find it in vi.lib. 🙂
And you know very well i don't decide the version at this place. 😉
Qestit Systems
Message 7 of 8
(3,429 Views)
The complaint was about using the property (https://labviewwiki.org/wiki/VI_class/Front_Panel_Window.Open_property), which the TBD certainly did use until recently.
Message 8 of 8
(3,427 Views)
