BFFF0000 Error Serial Communications
I am using several bluetooth virtual serial communications ports to transfer data from a pic microprocessor. I am using the generic VISA serial pallete to open, read, and close the port properly. However, once and a while I get an Unknown System Error 0xBFFF0000 when I try to open the port. If I attempt to open the port a few times it will eventually work.  I was wondering if anyone has any ideas as to what the cause could be. I have no idea since the error is very non descriptive. Any help would be appreciated.
(4,731 Views)
Hi cmeehan,
This error could mean a number of things. What's the hardware you are using for this application?
Raj
(4,705 Views)
The hardware is all custom made by me. It is a pic microprocessor which reads analog voltages, digitizes it and streams the data through a bluetooth transmitter to a bluetooth receiver on my computer. In windows, it is a simulated rs232 com port. Is there anyways to narrow down where the error occurs, other than just the VISA open com port?
(4,697 Views)
Hi cmeehan,
You can run a Spy Capture as you run your application and see what values are being passed on the bus. The details on how to perform a good NI Spy Capture can be seen here.
Raj
(4,680 Views)
hi!! i have same the problem, i uesd the one hardware, the computer hardware manage can to get the device, bur inside the NI-Max, it can't used the device
you can look the attach file picture, so how can to work the visa device???
(4,268 Views)
