BAD Offset Null
Hi, all. I measure strain with half-bridge strain gages. I use offset null, but if i change rate samples everytime i get different values from zero. I now that is a ghosting, but is there a method or calculations to now what is exactly rate for me to get zero values on non loaded strain gages?
P.S. I get approximately zero on rate = 15000 s/s
(3,281 Views)
Accepted by topic author stefo83
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
I'm guessing you already read that, so the real answer to how fast can you sample, will depend on the impedance on the system, and how fast a high impedance load switching between channels can stabilize.
(3,204 Views)
