Ayuda
Tengo que sumar el numero de veces que se cumple una condicion booleana??
Ejemplo;
cuantas veces prende un led.. sumar las veces que su condicion fue TRUE
gracias
Message 1 of 8
(4,372 Views)
translated by google:
I have to add the number of times a Boolean condition is met?
example;
LED lights a few times .. add the times your condition was TRUE
thanks
Is this a real LED or a control or indicator on the front panel? What makes the LED blink? How do you detect if the LED is on (light sensor, digital input, polling, etc.). What is the maximum rate at which it can change?
Can you show us a simplified version of your program?
You probably want to count how many times it went from OFF to ON.
Message 2 of 8
(4,334 Views)
Hola Eduardo2416,
Gracias por utilizar los foros de National Instruments! Tal como Altenbach menciona, necesitamos mas información sobre lo que deseas realizar. Esta señal booleana viene de un LED fisico o es una señal de control de software (bandera)? Te hice un ejemplo muy sencillo de como podrías comenzar pero todo va depender de lo que desees realizar.
Espero que esta información te sea de utilidad!
Luis CT
Message 3 of 8
(4,301 Views)
LuisC_AE wrote:
What is the purpose of the "equal true" function?
Message 4 of 8
(4,296 Views)
Hi Luis,
you made the classic Rube-Goldberg: IF "Boolean equal to true" THEN true ELSE false… 😄
Message 5 of 8
(4,294 Views)
Hi guys!
Oh yeah! My mistake lol. It was very very quick example that I didnt even notice that "double" verification. Eduardo you can get rid of that verification, here's a better code:
Regards!
Luis CT
Message 6 of 8
(4,289 Views)
SInce we don't really know how the LED status is read by the code, "latch action" might be unrealistic.
Here's a code alternative that works for any type of mechanical action. (currently set to switch until released, like a car horn ;))
NOTE: The code would be even simpler with this idea implemented. 😄
Message 7 of 8
(4,281 Views)
Thanks Altenbach! That is definitely a better way to go.
Eduardo, hope you find these examples useful for your application or project.
Best Regards!
Luis CT
Message 8 of 8
(4,273 Views)
