Axes scaling and Intensity Graph
I use a Intensity Graph to display measured data. Sometimes the X/Y-axis has to be transformed via the 1/x Operation and some other nonlinear transformations. Now I don't know how to let the Intensity Graph display the data correctly.
E.g. I use a normal X/Y Graph. After the 1/x operation the space between the data points are not equidistant anymore. This probably works because the XY-Graph needs the X AND Y Axis.
How can I do this with the Intensity Graph? Is there a simple solution or do I have to use the "picture" or somehting else?
(3,018 Views)
Greetings!
You might need to use the arbitrary marker spacing. (click on the legend and look at the options) YOu can then assign a new color to each increment you select. You can also play around with the gradients, (color interpretation) but I suggest you only do that after you have your markers where you want them. I'm sure you can get nice results with the intensity graph.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,018 Views)
