Availability of legacy Labview to support DSP2200?
I recently aquired an AT-DSP2200 DSA card for intended use in RTA and benchtop AF applications.  I have installed the card and have it working through NIDAQ 4.9.1.  However, per documentation, my current versions of Signal Express and Labview (8.1) will not recognize the card.  I am wondering what software options exist for gathering and viewing data from this card.  I would be perfectly happy to install Labview 5.1 or the equivalent as integration with later software packages isn't necessary.
My question is if anyone knows where Labview 5.x can be aquired or, if not, what options currently exist to make use of this card.
(2,473 Views)
Hello Jim,
Thanks for contacting National Instruments.
NI no longer supports LabVIEW 5.1 and it cannot be officially purchased any more.  It is also possible to program using a text based language for your device.  Traditional NI DAQ 4.9 includes compilers for MS Visual C++, Visual Basic, Turbo Pascal, and Borland C++.  The installer.zip file includes more information regarding the use of third party compilers with Traditional NI DAQ 4.9.
Browning G
FlexRIO R&D
(2,449 Views)
