Availability of Matrox Imaging Library driver?
Does anyone know if there is a Matrox Imaging Library for LabVIEW?. Commercial or otherwise.
(4,000 Views)
I could not find any on NI's Instrument Driver website (http://www.ni.com/devzone/idnet/). You might want to try contacting the vendor and see if they offer anything. It will certainly make your like a lot easier!
J.R. Allen
(3,999 Views)
There are commercial VIs for driving Matrox Meteor2 frame grabber. I guess they are based on Matrox Imaging Library.
http://www.alliancevision.com/us/products/software_alv/meteor2/fr_meteor2.htm
Instead of using the image processing function of Matrox MIL you could also use the functions provided with IMAQ Vision. Both libraries provide almost the same functionality but with IMAQ Vision your are already in the "LabView domain".
As your question is quite old: Did you found a free one? I need to make some frame grabbing with Matrox Orion and would like to stick to the "LabView domain".
(3,952 Views)
