Autosizing clusters LabView 2010 SP1
Hello!
I can't find settings where could I disable autosizing clusters.
Since I have installed LabView 2010 SP! my VIs are deformed in size due to clusters are resized to full size in while loops/ case loops.
Where can I disable ful size by default?
I have not this problem on my old machine where LV 2010 was installed.
Thanks in advance!
(2,531 Views)
Are you referring to the instance where a typedef cluster constant on the block diagram changes shape size after you have edited the type def? That is a known issue, and I don't know why it wouldn't have occured on another machine. I handle this problem, when I have very big typedef cluster constants, by encapsulating them in their own sub-vi, then the icon to be placed on the diagram can be made 1 terminal high if desired, so that it doesn't change size and can be made quite small.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,503 Views)
